downloaded a movie file in in bin and cue in know its svcd mpeg-2 i mounted the image with deamon tools but it wont play it wont work. i burnt the image using nero and works fine in my dvd player. i had stinky's mpeg-2 codec. i have now downloaded the k-lite codec pack i can get the audio to play media player classic but the screen is blank. i want to convert to dvdr using TMPGEnc but it wont it wont recognise it just says file unsupported. Can anyone help please. (i also have divx player and real player installed)
If you want to convert SVCD directly to DVD using TMPGEnc, the following plugin may help:
https://www.videohelp.com/tools?tool=243#comments
A software DVD player should be able to play that SVCD no problem. Have you tried playing it in PowerDVD or something?
Good luck with your conversion.
Cobra
Playback problems
By erica12 in forum Newbie / General discussionsReplies: 7Last Post: 16th Feb 2012, 19:33 -
VHS-C playback problems
By kicsrick in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2009, 12:43 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19 -
Playback problems
By Dick Stilton in forum Newbie / General discussionsReplies: 4Last Post: 26th Aug 2007, 07:21 -
DVD Playback Problems
By thelethal in forum Video ConversionReplies: 7Last Post: 4th Jun 2007, 14:08
