Hey,
I am going to start converting all my DivX DVD Rips into XVCD. I am going to get them to fit onto one CD, using low audio (128k) and lower bitrate (around 950).
What filters (from TMPG) should I use to keep quality maximum?
And just a question about Nero, how good can you get them menus to be? Can you make it chapters "seemless" or close to it?
Anything else I should consider? Thanks.
I just did Broken Arrow DivX into xVCD. I first loaded Nero up and dragged file across, it said it was 97 mins long (it is, but file size is only 760mb) and wouldnt burn. So I did a multiplex and demultiplex thingo as Non-Compliant VCD settings. And then it said it was 76 minutes.
I burnt it and went to play on my standalone VCD player and the video playback was a little choppy, but cleared up and the sound was playing up (every 1 second, 1 second of audio would cut out and stuff). Is there anyway to get it working? I am pretty sure my Sony VCD Player can handle xVCDs.
Would be good too coz Bitrate was at 950 and sound was at 128kbps and video quality was great.
Thanks.
3d questions
By alucard2050 in forum DVB / IPTVReplies: 16Last Post: 22nd Aug 2010, 00:01 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
New to DV, I have several questions.....
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 4th Dec 2007, 00:10 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 15:00
