TMPGEnc DVD Author is taking 30-40 mins to compile my DVDs on an XP2200 with 512Mb RAM. As far as I can gather, all of the MPEGs are compliant and nothing is being re-encoded. I have about 70 x 5-sec motion menu thumbnails but turning motion menus off completely doesn't seem to change the duration that much. Is this speed normal? Most of the time seems to be spent writing the main files and I am worried the software is doing something I don't know about (especially with the audio). Everything is encoded using MainConcept MPEG Encoder using the standard MPEG2 template but audio at 384kbps.
Also I capture and encode in D2 (half D1) a lot and I've discovered that TMPGENC DVD Author won't accept the D2 size MPEGS at all when they are encoded with the 16:9 flag set rather than 4:3. Any thoughts? Should I encode them at 4:3, but then I'll have to switch the AR manually on TV? Its annoying because my DVD player plays them perfectly in 16:9 from an ISO DVD.
That sounds about right. I use a Pentium 4 w/512 Meg for full and 1/2 D1, usually 4:3 and it takes about the same time.
It takes my system 15 minutes to compile,background apps and or virus scanners might slow down your time.If your audio is 44khz then that will be resampled and take more time.
i have a celleron 800mhz with 192 megs of ram and it takes me aa good 20-25 to compile a full disc if i leave the computer alone. if i do anything else at the same time it takes much longer.
Long silence in ac3 is mysteriously shortened when I author
By Genaugmen in forum Authoring (DVD)Replies: 0Last Post: 20th Aug 2010, 17:47 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
