I have this problem with the most recent movies I've ripped. Everything seems to be OK during the burning process. When I play the burned discs however, they stop reading after a while, usually after 60-90 minutes. The movie just freezes. I use cheap no-name discs, but they have worked for me before.
I use DVD Shrink and Clone DVD.
What can the problem possibly be?
Thanks in advance for any help!
Originally Posted by Mikael
My car worked yesterday but will it hell as start tonite......Not bothered by small problems...
Spend a night alone with a mosquito -
Thank you, but I've now tried three different media brands, with the same result. I strongly suspect that there is something wrong with my burner, a NEC 1300A.
I've tried discs called SW-Technology, Princo and Platinum. All with the same result. I know, they are all cheap brands, but since all of them have worked fine for me before, I'd say that this is definitely not a media problem.
I've tried the faulty discs on both of my standalone players, and software players, and they behavaved more or less the same in all of the players.
DVD Info Pro reported hundreds of LBA errors after 70 percent of reading.
I need a drink. -
The other two, EPSECIALLY Platinum, are pure trash.
Cheap media is a gamble that often loses.
Either buy 1 good disc for $1 ... or 10 bad ones for 10 cents each.
In the end, it all evens up.Want my help? Ask here! (not via PM!)
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS -
I remember an old saying "Penny wise and pound foolish"
AVI on CDRW stops playing in DVD player?
By leonk in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2012, 21:53 -
Ripped video stops randomly for 1 or 2 seconds
By panning in forum ffmpegX general discussionReplies: 2Last Post: 29th Oct 2011, 05:17 -
Runtime Error playing back ripped DVD folder
By oshanruiz in forum DVD RippingReplies: 0Last Post: 14th Jul 2011, 11:15 -
Playing ripped dvd in ps2
By hrgrosskopf in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2008, 08:04 -
Ripped/burned AVI DivX files not playing in pc or DVD player
By perceptionist in forum DVD RippingReplies: 13Last Post: 4th Jun 2007, 03:55
