Anyone? Or should I wait for the ones with a hard drive in them?
Results 1 to 10 of 10
JVC DRM10SL
ejai,
I realy appreciate your honest posts and comments on this site. From your two previous posts I found that you have some serious issues with this JVC model:
My findings are there is a slight sync issue with the JVC recorder. I made several identical recordings using the E50 and the the JVC and if you look reallllll close you will notice the lips don't sync up with the audio on the JVC captures. Yet the E50 clips are perfect.In spite of your comments, will you, please, explain why you still think that the JVC DVD recorder is superior to Panasonic models.Yet the over 2hr mode does not do well on fast moving scenes, in my opinion the Panasonic does a better job there. I have some dance video that is at least 2:30mins long and the video is very pixelated on some parts where the dancer has a lot of movement. The same video clip captured using the Panasonic shows very little pixels.
For me, as a profesional, the relaibility and the consistent quality of the recordings is more important than the slight edge in the picture quality under specific circumstances. -
Panasonic makes lots of corrupts files. I've got a stack of discs here that are bad because of AC3 corruption and bad PTS info.
There's nothing definitive on the sync issue as I don't believe anyone other than ejai has seen this with their JVC.Originally Posted by zorankarapancev
The high-motion video artifacting might have been due to the Panasonic dropping to half D1 (352x480) resolution on recordings longer than two and a half hours, which would account for less compression artifacting than the JVC's full D1 (720x480) recording of the same length. However, I'm not sure that was the cause, just a possibility. I have both the Panasonic and the JVC, and the JVC is clearly superior as far as PQ goes.
ejai?
How can I show subtitles on the the top line and on the bottom line.
By Dracko in forum Authoring (DVD)Replies: 14Last Post: 8th May 2014, 15:03 -
Help! Mpeg2 encoder shifts image up and adds a line at the bottom
By Asterra in forum Video ConversionReplies: 13Last Post: 10th May 2010, 19:57 -
green line at bottom of video window
By miniboss91 in forum Video ConversionReplies: 3Last Post: 11th Jan 2010, 21:51 -
There is a narrow line at the bottom of my screen.....
By gom in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 12:16 -
Horizontal Line near bottom of video
By tdelarosa in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2007, 15:09
, JVC
