  1. Member beammeup's Avatar
    Oct 2003
    Australia
    Hi,
    Does anyone know which setting is best for transcoding PAL to NTSC
    I'm looking for the smoothest possible conversion, trying to avoid Judder effect as much as possible
    In Procoder, under transcoding settings / frame rate conversion
    Which one is best?
    Always interpolate
    or
    Interpolate, but pick nearest when time difference is too large
    The Threshold ms setting is default on 11
    Any advice appreciated
    Cheers
  2. Member erratic's Avatar
    Oct 2003
    Belgium
    Try the Canopus forum.
    http://forum.canopus.com/
    You need to register as a new user before you can read all the forums.
    Without registering the ProCoder forum doesn't even show up.
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    well first of all -- use procoder 2 and it is a no brainer ...
    untill you upgrade to 2 (which works differently than 1.5) it is a moot question ..
    procorder express also will work as version 2 though ..
