  1. my dvd player won't play vcd 2.0 format movies. help
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    buy a dvd burner?
    what do you want help with, exactly?
    Dec 2002
    My Swamp
    Is it meant to ???
    Not all DVD Players play VCDs
  4. Member Grimey's Avatar
    May 2004
    Canada Eh?
    Burn as a vcd 1.0, or as flan said, buy a dvd burner, or buy a new dvd player.
  5. i used to be able to play vcd or svcd on my dvdplayer but the recent movies i burn are in vcd 2.0 format wat is it and wat do i do about it. cant i convert it to an mpg or vcd format
  6. Member Grimey's Avatar
    May 2004
    Canada Eh?
    So you used to burn movies in vcd 1.0 but now you burn them in vcd 2.0 and now they don't play? If I understand this correctly, couldn't you just go back to burning them as vcd 1.0?
  7. that how they come when i burn them, im guessing that the svcd that i used to get were in vcd 1.0 format.
