Im using the latest version 317. I open my vobs ripped with decriptor, reautor, then choose the main movie file, it show my compression is at 69.5, the file size is 4464. Saved it to my disk for nero buring, but somehow in Nero it say the file is too big won't fit my dvdr like near 5 gigs or so. Another problem is that sometime during the encoding, I would receiver an error saying "out of memory" or somthng like that. Please help!!!
[quote= "programming error exception somthing" or somthng like that. Please help!!![/quote]
If this is happening all the time, it's likely a misconfiguration.
But if it happens occasionally, it's due to a "bug" in DVD Shrink that makes it sometimes pick the wrong size for the output. You can either:
1. Shrink it again (not a good idea).
2. Turn on Advanced Analysis (takes longer, but more likely to hit the target size).
3. Set a target size a little smaller than the size of a DVD, in order to "trick" DVD Shrink into making the output the correct size.
- Gurm -
vitamine, what is the version of Nero are you using?
hi guys...Im using the nero 1035 somthing the enterprise version. Im not sure what's going on, but Im changing out my mobo and cpu and ram and will install the latest nero and will try to encode again and will get back. Thanks...please check back.
Well, somehow after I switched my rig to a brand new nforce rig and xp3000 and add 1 gig of memory eveyrything is smooth and working perfectly now. Thanks all for helping
i was about to post that an overclocked P3 could be the problem.......
Video frame size ,i don't konw,help me!
By xieliancheng in forum Authoring (Blu-ray)Replies: 1Last Post: 1st Jul 2010, 10:52 -
Portable Scanner by VuPoint: how do i make scans fit 8x11 letter size ?
By vhelp in forum ComputerReplies: 4Last Post: 6th Jun 2010, 16:37 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
How to burn DVD files that don't fit on DVD?
By aqualung2003 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2007, 00:43
