it started happaning to me today, and it happend to another person what can i do to solve it?
Log:
nitializing
WARNING! You seem to be using "Norton Unerase Protection" and
you want to delete the temporary files created by dvd2svcd.
This can cause DVD2SVCD problems. Even though DVD2SVCD deletes
the temporary files, Norton doesn't, therefore DVD2SVCD
might run into diskspace problems. I suggest that you stop the
"Norton Unerase Protection" Service.
- D:\Programs\úåëðåú ùéúåó\eMule\incoming\*****.avi
Initializing finished.
Saving Subtitles ini file
- 28/06/2004 15:19:42
- Free on drive D: 34965.07 mb
- AUDIO Extraction
Undoing Nandubs 1152 BlockAlign value to 1
Redoing Nandubs 1152 BlockAlign value
Audio extraction finished.
- 28/06/2004 15:26:56
- Free on drive D: 34702.81 mb
- AUDIO conversion
Converting MP2 to WAV. Filename: D:\DVD\DVD2SVCD\Movie\Extracted_audio_1.mpa
Executing MADPlay (mp2 to wav). Commandline:
"D:\DVD\DVD2SVCD\MADPlay\madplay.exe" --quiet --output=wave:"D:\DVD\DVD2SVCD\Movie\Encoded_audio_1 .mp2.wav" "D:\DVD\DVD2SVCD\Movie\Extracted_audio_1.mpa"
Conversion (mp2 to wav) of D:\DVD\DVD2SVCD\Movie\Extracted_audio_1.mpa finished.
Encoding Audio. Filename: D:\DVD\DVD2SVCD\Movie\Extracted_audio_1.mpa
Executing BeSweet. Commandline:
"D:\DVD\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "D:\DVD\DVD2SVCD\Movie\Encoded_audio_1.mp2.wav " -output "D:\DVD\DVD2SVCD\Movie\Encoded_audio_1.mp2" -logfile "D:\DVD\DVD2SVCD\Movie\Encoded_audio_1.log" ) -ota( -g max ) -shibatch( --rate 48000 ) -2lame( -e -b 224 -m s )
Audio conversion of D:\DVD\DVD2SVCD\Movie\Extracted_audio_1.mpa finished.
Audio conversion finished.
- 28/06/2004 15:37:51
- Free on drive D: 32495.21 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 4546875788
AudioSectors: 342357736
VideoPAPO: 65130228
ScanOffsetBytes: 433616
SeqAligningBytes: 27558674
DVDBytes: 0
VideoEndHeader: 4
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 0.00
PureMPEGStream: 4111395530.50
Seconds: 12063.93
CalcMPEGStream: 4111395530.50
Frames: 289077
CDSize: 4350.00
Number of CDs: 1
Cut point 4345.00
Variable Settings:
Frames: 289077
Anti Noise Filter: Off
Passes: 2
Image Quality: 22
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 200
Max. bitrate: 9000
Avg. Bitrate: 2726
Aspect Ratio: 16:9 (borders added, encoded as 4:3)
---AVS Begin---
LoadPlugin("D:\DVD\DVD2SVCD\AVISYN~1.5PL\Mpeg2dec\ MPEG2D~1.DLL")
AVISource("D:\Programs\CBCF~1\eMule\incoming\THELO R~3.AVI",audio=false)
ConvertToYUY2()
BicubicResize(720,360,0.0,0.6)
AddBorders(0,60,0,60)
Import("D:\DVD\DVD2SVCD\Movie\ResampleAudio.avs")
ResampleAudio(44100)
----AVS End----
- 30/06/2004 14:10:53
- AVI to SVCD Conversion
- AVI2DVD ver. 1.2.2 build 1
Initializing
- 30/06/2004 14:11:03
- Free on drive D: 32632.42 mb
- Crash Recovery
- Restarting from: Video encoding
- 30/06/2004 14:11:23
- Free on drive D: 32632.40 mb
VideoPAPO: 65130228
DVDBytes: 0
VideoEndHeader: 4
SubtitleSectors: 0
Seconds: 12063.93
Frames: 289077
CDSize: 4350.00
Number of CDs: 1
Cut point 4345.00
Variable Settings:
Frames: 289077
Passes: 2
Image Quality: 22
Min. bitrate: 200
Max. bitrate: 9000
Avg. Bitrate: 2726
---AVS Begin---
ConvertToYUY2()
----AVS End----
Closing program
CCE Max Speed: 2.690
Video Encoding finished.
- 30/06/2004 17:59:17
- Free on drive D: 29024.95 mb
- Video Pulldown
Executing Pulldown. Commandline:
"D:\DVD\DVD2SVCD\pulldown\pulldown.exe" "D:\DVD\DVD2SVCD\Movie\Encoded_Video_CCE_NTSC. mpv" "D:\DVD\DVD2SVCD\Movie\Pulldown_Encoded_Video_NTSC .mpv" -prog_frames p
Video pulldown finished.
- 30/06/2004 18:12:58
- Free on drive D: 25106.93 mb
- Multiplexing Audio and Video
Executing MPlex. Commandline:
"D:\DVD\DVD2SVCD\DVDAuthor\mplex.exe" -f 8 -o "D:\DVD\DVD2SVCD\Movie\MPlex_Muxed_File00.mpg" "D:\DVD\DVD2SVCD\Movie\Pulldown_Encoded_Video_NTSC .mpv" "D:\DVD\DVD2SVCD\Movie\Encoded_audio_1.mp2"
- 30/06/2004 18:13:09
- Determining length of audio
Analyzing finished.
Saving Subtitle Timecodes.
SVCD subtitles.
- 30/06/2004 18:13:42
- Free on drive D: 25103.17 mb
- Multiplexing Subtitles
Executing SpuMux. Commandline:
"D:\DVD\DVD2SVCD\DVDAuthor\spumux.exe" -m dvd -s 0 "D:\DVD\DVD2SVCD\Movie\iw1-1.xml" < "D:\DVD\DVD2SVCD\Movie\MPlex_Muxed_File00.mpg" > "D:\DVD\DVD2SVCD\Movie\MPlex_Muxed_File00-subbed.mpg"
SpuMux failed for unknown reasons!
For details open: "D:\DVD\DVD2SVCD\Movie\SpuMux_log.txt"
- 01/07/2004 08:52:48
Initializing
- 01/07/2004 08:53:32
- Free on drive D: 25098.54 mb
- Crash Recovery
- Restarting from: Muxing and Cutting
- 01/07/2004 08:53:34
- Free on drive D: 25098.52 mb
- 01/07/2004 08:53:36
Analyzing finished.
SVCD subtitles.
- 01/07/2004 08:54:09
SpuMux log:
D:\DVD\[removeme]DVD2SVCD[removeme]\DVDAuthor>"D:\DVD\[removeme]DVD2SVCD[removeme]\DVDAuthor\spumux.exe" -m dvd -s 0 "D:\DVD\[removeme]DVD2SVCD[removeme]\Movie\iw1-1.xml" 0<"D:\DVD\[removeme]DVD2SVCD[removeme]\Movie\MPlex_Muxed_File00.mpg" 1>"D:\DVD\[removeme]DVD2SVCD[removeme]\Movie\MPlex_Muxed_File00-subbed.mpg"
The system cannot find the file specified.
MPlex Log:
INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
INFO: [???] File D:\DVD\[removeme]DVD2SVCD[removeme]\Movie\Pulldown_Encoded_Video_NTSC.mpv looks like an MPEG Video stream.
**ERROR: [???] File unrecogniseable!
**ERROR: [???] Unrecogniseable file(s)... exiting.
Help! Plz Help!
Try to play the *.mpv file in a media player.
Open the *.avs file generated with DVD2SVCD in VirtualDubMod and look for errors from VDMod.
Overall the speed from CCE is very high for such resolution. Obviously mplex cannot deal with encoded file. That means it is crap inside, or maybe CCE encoded an error mesage from Avisynth.
Good luck with debugging. -
MPlex Log:
INFO: [???] File D:\DVD\DVD2SVCD\Movie\Pulldown_Encoded_Video_NTSC. mpv looks like an MPEG Video stream.
**ERROR: [???] Unrecogniseable file(s)... exiting. -
Hi!
I have a very similar problem! But I got these logs:
DVD2SVCD:
Code:WNASPI32.DLL 4.71.1.0 -------------------------------------------------------- - 2004.08.10. 9:34:38 - AVI to SVCD Conversion - AVI2DVD ver. 1.2.2 build 1 -------------------------------------------------------- Initializing WARNING! You seem to be using "Norton Unerase Protection" and you want to delete the temporary files created by dvd2svcd. This can cause DVD2SVCD problems. Even though DVD2SVCD deletes the temporary files, Norton doesn't, therefore DVD2SVCD might run into diskspace problems. I suggest that you stop the "Norton Unerase Protection" Service. - D:\BitTornado Letöltés\Azureus\Film\Film.avi Initializing finished. Saving Subtitles ini file -------------------------------------------------------- - 2004.08.10. 9:34:44 - Free on drive C: 8646.22 mb - AUDIO Extraction -------------------------------------------------------- Audio extraction finished. -------------------------------------------------------- - 2004.08.10. 9:37:05 - Free on drive C: 8646.09 mb - AUDIO conversion -------------------------------------------------------- -------------------------------------------------------- - 2004.08.10. 11:28:10 - AVI to SVCD Conversion - AVI2DVD ver. 1.2.2 build 1 -------------------------------------------------------- Initializing WARNING! You seem to be using "Norton Unerase Protection" and you want to delete the temporary files created by dvd2svcd. This can cause DVD2SVCD problems. Even though DVD2SVCD deletes the temporary files, Norton doesn't, therefore DVD2SVCD might run into diskspace problems. I suggest that you stop the "Norton Unerase Protection" Service. - Initializing finished. -------------------------------------------------------- - 2004.08.10. 17:29:08 - AVI to SVCD Conversion - AVI2DVD ver. 1.2.2 build 1 -------------------------------------------------------- Initializing WARNING! You seem to be using "Norton Unerase Protection" and you want to delete the temporary files created by dvd2svcd. This can cause DVD2SVCD problems. Even though DVD2SVCD deletes the temporary files, Norton doesn't, therefore DVD2SVCD might run into diskspace problems. I suggest that you stop the "Norton Unerase Protection" Service. - Initializing finished. -------------------------------------------------------- - 2004.08.10. 17:29:47 - Free on drive D: 9334.75 mb - Crash Recovery - Restarting from: Video encoding -------------------------------------------------------- - 2004.08.10. 17:29:49 - Free on drive D: 9334.75 mb - Video Encoding using Cinema Craft -------------------------------------------------------- Executing Cinema Craft Encoder. StreamSectors: 4546875788 AudioSectors: 172914896 VideoPAPO: 67754988 ScanOffsetBytes: 266501 SeqAligningBytes: 16937587 DVDBytes: 0 VideoEndHeader: 4 SubtitleSectors: 0 EmptySectors: 238.00 PictureSectors: 0.00 PureMPEGStream: 4289001812.17 Seconds: 7108.68 CalcMPEGStream: 4289001812.17 Frames: 177667 CDSize: 4350.00 Number of CDs: 1 Cut point 4345.00 Variable Settings: Frames: 177667 Anti Noise Filter: Off Passes: 2 Image Quality: 17 VAF file creation: On Video Encoding Mode: Multipass VBR Min. bitrate: 800 Max. bitrate: 8000 Avg. Bitrate: 4826 Aspect Ratio: 16:9 (borders added, encoded as 4:3) ---AVS Begin--- LoadPlugin("C:\PROGRA~1\DVD2SVCD\AVISYN~1.5PL\Mpeg2dec\MPEG2D~1.DLL") AVISource("D:\BITTOR~1\Azureus\FILM\FILM.AVI",audio=false) ConvertToYUY2() LanczosResize(720,295) AddBorders(0,140,0,141) Import("D:\DVD2SVCD kimenet\ResampleAudio.avs") ResampleAudio(44100) ----AVS End---- Closing program CCE Max Speed: 1.060 Video Encoding finished. -------------------------------------------------------- - 2004.08.10. 23:10:48 - Free on drive D: 5424.35 mb - Multiplexing Audio and Video -------------------------------------------------------- Executing MPlex. Commandline: "C:\Program Files\DVD2SVCD\DVDAuthor\mplex.exe" -f 8 -o "D:\DVD2SVCD kimenet\MPlex_Muxed_File00.mpg" "D:\DVD2SVCD kimenet\Encoded_Video_TMPGEnc_PAL.mpv" "" -------------------------------------------------------- - 2004.08.10. 23:10:54 - Free on drive D: 5424.35 mb - Determining length of audio -------------------------------------------------------- Analyzing finished. Saving Subtitle Timecodes. SVCD subtitles. -------------------------------------------------------- - 2004.08.10. 23:11:40 - Free on drive D: 5424.35 mb - Multiplexing Subtitles -------------------------------------------------------- Executing SpuMux. Commandline: "C:\Program Files\DVD2SVCD\DVDAuthor\spumux.exe" -m dvd -s 0 "D:\DVD2SVCD kimenet\Subs\hu1-1.xml" < "D:\DVD2SVCD kimenet\MPlex_Muxed_File00.mpg" > "D:\DVD2SVCD kimenet\MPlex_Muxed_File00-subbed.mpg" SpuMux failed for unknown reasons! For details open: "D:\DVD2SVCD kimenet\Subs\SpuMux_log.txt"
MPlex:
Code:INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $) **ERROR: [???] Unable to open file for reading.
So can you tell me why is it unable to open for reading?? I played the "Encoded_Video_TMPGEnc_PAL.mpv" (I used CCE, but I did a recovery and the first time I used TMPG and the filename did not changed) it works fine!!!
When I play the audio (Encoded_audio_1.mp2) it works fine too!!
Please, anybody who can, help me!
Thanks very much!!
VirtualDub: "AVI Import Filter error: (Unknown) 80040154"
By Xavier in forum Newbie / General discussionsReplies: 11Last Post: 15th Dec 2021, 17:49 -
sony DVD Recorder RDR-GX257 "unknown disc "msg
By corpjet in forum DVD & Blu-ray RecordersReplies: 2Last Post: 16th Feb 2010, 12:08 -
how to fix "WARN: unknown mpeg2 aspect ratio 1" in DVD Author GUI
By extent in forum Authoring (DVD)Replies: 10Last Post: 23rd Nov 2009, 07:57 -
How to Capture Video of "Unknown" Format from a DVD
By Hombre7 in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2009, 12:14 -
"Unknown Disc" error for all DVDs - is my player dead?
By RosieP in forum DVD & Blu-ray PlayersReplies: 6Last Post: 8th Nov 2007, 07:49
