WHAT is The Program
My Greeting![]()
8.5gb of what? Movie files? Data?
Assuming movie files, need to shrink to 4.37gb using dvd shrink, clonedvd or similar programs there are lots to choose from.
Read a guide, they do help
Bit more detail would have got the answers you need without confusion :
How do I burn 8.5GB onto a DVD
How do I fit 8.5GB on a DVD
etc, etc
But, if you want to fit 8.5GB of video onto a DVD, assuming its ripped first, simply use any transcode software
DVDShrink is free and well used and supported
Nero Recode 2 is basically an improved commercial DVDShrink
DVD2One is very fast and pretty cheap to buy
Intervideo DVD Copy 2 produces very good results -
I don't know if you're talking about a simple DVD-R or a DVD+R DL, in that case you may want to check my thread: https://www.videohelp.com/forum/viewtopic.php?t=227931
BY MAGIC.
The DVD gremlins come out at night, and coat all DVD's with special "DVD Dust".
This DVD Dust enables you to use your pixie magic on the DVD's, and put 8.5GB of data on them!
All you have to do is put on your ruby slippers, click your heels together, and say:
"There's no place like home! I believe in fairies!"
And then the blue fairy will make you into a REAL boy, and you can save your father from the belly of the whale!
- Gurm
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
