I probably didn't say that right but I think you know what I mean. I'm using TMPGEncDVDAuthor and I can't put my movie on a DVD because its 480x480. I already change the audio to 48000hz. Is it a program that change the video?
You would have to re-encode the video to 720x480 before it would be DVD compliant. You can use TMPGEnc or TMPGEnc Plus to do that, then you can use TMPGEnc DVD Author to make the DVD. TMPGEnc Plus has a easy wizard to walk you right through the process.
It is possible (sometimes anyway) to put 480x480 mpegs on a DVD and have them play, though it is non standard and some players may not play them correctly if at all.
If you want to try this, probably the easiest wat is to take a look at SVCDMPGTODVD (I think thats right!). -
use dvd patcher. i think you'll have to still convert the audio to 48 khz but the vid will be perfect
Originally Posted by m2mic"Art is making something out of nothing and selling it." - Frank Zappa
If the bitrate is high enough, for example movies up to around 2 hours if encoding at VBR, you can safely size it up. I am very satisfied with the results i had so far. Use Bicubicresize, with blurring if necessary - for ex 0.2, and set ringing to 0.5 or 0.6. If encoding to 4:3 i dont like to use 720x480, 704x480 should be more optimal for keeping aspect ratio when played on TV. And just in case: Syntax for BicubicResize in AviSynth is Bicubicresize(horizontalsize, verticalsize, blur, ring) when working with a single clip.
Change video to another format?
By Venessa@123 in forum Newbie / General discussionsReplies: 5Last Post: 10th Aug 2011, 02:10 -
Please Help !!! How to change the audio format (only) of an Xvid/AVI ??
By moiz in forum User guidesReplies: 3Last Post: 15th Oct 2008, 12:30 -
rip AC3 track without format change
By shun in forum DVD RippingReplies: 2Last Post: 9th Feb 2008, 03:01 -
Premiere - how do I change capture format?
By djbryson in forum Capturing and VCRReplies: 15Last Post: 17th Nov 2007, 09:42 -
Can I Change Format???
By jmarkt in forum Authoring (DVD)Replies: 2Last Post: 30th Jul 2007, 15:48
