1. Well Im dual booting windows 2000 and xp. I recently installed a new hard drive and installed a fresh copy of xp. When I turn on my computer it says:
Windows XP
Windows XP
Windows 2000
The second one doesnt work its for a hard drive that doesnt exist. How do I get rid of the 2 Windows XP option.
2. When I was installing xp for some reason it didnt install internet explorer. So no problem, I install Firefox and go download it from mircosoft site. But when I install it, it installs on my windows 2000 partion everytime(Cinstead of my xp partion.
3. How do I re-organize Drive letters, I've done so much playing around that my windows XP Partion is P: and my 2 backup partions are all over the place, I would like to make win xp partion d: and 2 backup partions e: and f:
thx for any help
i think you should format and start again......
XP without IE? didn't think that was even possible......................... -
Originally Posted by flaninacupboard
XP without IE? Micro$oft would probably says that is a violation of XP usage -
I fixed the first one my modifying boot.ini and the second by going to add remove windows component.
Still working on 3rd...... -
Go to settings....control panel....system.
Click on the advanced tab, there should be a option called 'startup and recovery' if so, click settings.
There you will find an optin to edit the startup options. Click on the 'edit' button, and it will open a notpad file called 'boot'
Simply remove the line with the OS or OS's that you no longer have.We'll be right back after these messages from Binford! -
Yes I did a search, and no I did'nt need to post my question because I just got the answer! :P
Can I re-install older dual-boot OS and still have the dual-boot work?
By jeanpave in forum ComputerReplies: 8Last Post: 3rd Dec 2011, 01:06 -
Dual Boot or use SSD for storage?
By neworldman in forum ComputerReplies: 4Last Post: 2nd Dec 2011, 07:27 -
dual-boot systems
By joecass in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2011, 20:01 -
Creating a dual boot system...best way?
By sdsumike619 in forum ComputerReplies: 11Last Post: 14th Dec 2008, 11:30 -
Dual Boot OS use 1 or 2 keys?
By johnhammonds in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Apr 2008, 05:20
