I have been using 4x BulkPaq DVD-Rs ever since i got my LG DVD-RW drive.
I ran out of discs and bought new Infiniti 4x DVD-Rs. However when i try to write something now, it says it will write at 2X and i am unable to change it to anything other than 2x.
Results 1 to 10 of 10
Do you have the latest firmware on your burner?
DVDInfoPro should give you that. The app is free to try, so I suggest you download it and check your burner. You don't want to flash the firmware if you already have the latest.
Check for the latest firmware from the manufacturer's site. If it isn't the latest, the burners sometimes don't burn the newer media at the fastest speed
http://www.lge.co.uk/mod_perl/go.pl/site/products/pc/optical/dvdram.htm?product_uid=27...tegory_uid=648
HEre si the site, i see nothing about firmware. I searched the rest of the site too any i got nothing -
the infiniti white top dvd-rs i tried were supposidly 4 speed,but it turned out they were 2 speed only,and the replacements were the same.
when i went back to the store,there were quite a lot of them left in the store and the guy said they were gonna send em back,as they were 1 and 2 speed,repackaged as 4 speed.
when i did burn them,they burnt like the bulkpaq tango dvd-rs,meaning they were crap.
better off getting rid of them and getting some ritek,another good brand. -
i got excellent results with bulkpaq very compatible with stand alone's only problem i had was about 2% jumped. but have moved on to 8x arita now
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 16:25 -
DVD-Lab Pro: DVD-R DL burning problems
By jonghyunchung in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 07:57 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 14:34 -
Sync problems while authoring a DVD with DVD Flick
By TioSolid in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 13:21 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 18:00
