Hi. I have a bit of a problem that hopefully someone can help me with.
Every time I rip a DVD, I can't rip another one without rebooting the computer. If I put a new DVD in the drive, Windows XP won't recognize it. Thus, I can't rip it. However, I don't seem to have a problem burning one CD/DVD-R after another for some reason. Occasionally, I have a problem with CDs as well (can't read or rip another disc after reading the first one).
Hopefully I'm making sense. If any more info is needed, let me know. Thanks in advance.
-J.P.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 10 of 10
Knowledge is Power, For Real!
after your rip is finished, open my computer, right click your drive and choose "Eject" rather than just pressing the button on the drive. windows sometimes gets confused about what disc is in there, doing "Eject" works for me when it's being a bitch
Cool. I'll try that. Thanks, flaninacupboard.
By the way, your name wouldn't happen to be a reference to Eddie Izzard's routine, would it?Knowledge is Power, For Real! -
Originally Posted by TenaciousJP
Freaked me out last time someone worked it out, he just responded to my next post as "hi eddie," which was damn weird because my name's Edd! -
If so, it is a known problem with XP.
Change discs and go straight back into your ripping program. It knows the score and will work fine without having to reboot.If in doubt, Google it. -
Yeah, I remember the Flan in a Cupboard bit from his routine. Good stuff.
"Cake or death?"
"Cake, please."
"We're out of cake. Only had 3 bits, and didn't expect such a rush."
"I'll have the chicken, then."
"Here you are, sir. Tastes of human..."
jimmalenko, it's actually a different problem. When I put a new disc in the drive, it doesn't show up at all. In My Computer, when there is no disc in the drive, it usually just shows the icon of the CD drive with the drive letter. Normally, when you put in a disc, the icon changes to a disc icon and tells you what is in the drive.
I think I've tried going directly back to the ripping program, but all it said was "Waiting to read disc."
I'll definitely try those suggestions, though. Thank you both very much.Knowledge is Power, For Real! -
Sorry, I didn't make myself clear in my previous post. Let me clarify:
Before putting the disc in the drive, it shows up as (drive letter): and the icon of the CD drive. When you put the DVD in, it dispalys the label of the disc. You rip this, then if you've only got the one DVD Drive you take this disc out and place a blank in the drive. If you've got two drives you put a blank in your second drive. If you were to go to My Computer now, it would be show the drive letter and the image of the CD drive for the drive that contains the blank.
The known issue comes from after usage of a DVD Drive (either burning or ripping), you remove a disc, put another one in and it still shows the label of the previous disc in My Computer. Double-clicking shows you the correct files, but sometimes the label just doesn't change to the new disc.
This is not your problem by the sound of it though.If in doubt, Google it. -
both my brother & cousin have a pioneer 107 & the same thing was happening with them , they had any dvd running all the time , all they did was when they stopped ripping & burning they would exit any dvd & the drive would operate as normal.
Well, I tried using Eject from My Computer, and I still have the problem.
Whenever I put a new disc in the drive, it hums disapprovingly at me, and nothing shows up on My Computer. When I try to right-click/explore the new disc, My Computer will just freeze until I eject the disc.
This problem is really getting to me, but I'm sure that I'll find a way to fix it somehow. Once again, thanks for the help, and any new suggestions would be very appreciated.
-J.P.Knowledge is Power, For Real! -
i found something about this problem, but i dont know if
it will help you...
read this > http://support.microsoft.com/default.aspx?scid=kb;en-us;314939&Product=winxp
by the way, did you try uninstalling the drive from the device manager
and restarting the computer?
might helpHELL AINT A BAD PLACE TO BE
rip blue ray and watch it on computer (no encoding)
By chadkan in forum Authoring (Blu-ray)Replies: 2Last Post: 10th Dec 2011, 04:59 -
What format to rip my DVDs to my computer?
By SirMoby in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2011, 20:07 -
Rip to central server on my home network and stream to TV or computer
By RJC5XTC in forum DVD RippingReplies: 1Last Post: 13th Dec 2010, 20:03 -
Couldn't rip Vob files onto my computer. best program for mac.
By Tintin11 in forum DVD RippingReplies: 2Last Post: 3rd Nov 2010, 22:05 -
Can I rip videos of my DVD to my computer?
By LoveKota in forum DVD RippingReplies: 6Last Post: 15th Feb 2008, 01:36
