    Jun 2004
    nottingham uk
    just bought a pc and writer and have just had my dvd of my wedding sent to me,
    i have used dvd2one and then DVD Decrypter and
    have followed the help me files on burning with nero 6 and seemed to have burned ok with no errors but i go to play on my dvd player and get cant read disk
    any help would be good as like i said, new to this and i think im in it way over my head
    cheers all and great site
  2. When u say dvd player, do u mean the computer one or the standalone one. If u mean standalone, your player might not support reading the disc. Have a check on the left for compatibility.
    Also, if u use dvd+r then u might try bitsetting your discs to dvd-rom before burning, this increases the compatibility but not sure if your writer supports it. Can u give us the model and brand?
    Also if did use dvd+r, try dvd-r as they are reported to have more compatability although some may not agree with me.
    Jun 2004
    nottingham uk
    cheers for the reply, it wont play on my stand alone with tv, its a sony dvp-ns305 and im usinG DVD-R disks, my burner is a NEC DVD_RW ND-2500A
    is it right that when ripped to my ts folder i have a few files in there that are not recognised, i have 2 files that say windvd playback and 2 bup files
    Jun 2004
    nottingham uk
    VIDEO_TS
    VTS_01_0
    VIDEO_TS.BUP
    VTS_01_0.BUP
    these are the files that have been ripped but are not recognised in my ts folder
    the disks im using are packard bell dvd-r 1 x speed, but i have orded 50 {DV 3071/25} Ritek Inkjet Printable A Grade (4x) DVD-R
    are these disks any good, recomended from a friend on a web site
  5. Member Treebeard's Avatar
    Aug 2002
    So this is your wedding somebody put on dvd? If so then its probably a burned dvd not factory produced (stamped) and no copy protection.
    If this is correct then just use dvd decrypter to do an ISO read then burn the iso to a new blank dvd, yes ritek are generally good discs.
    Jun 2004
    nottingham uk
    many thanks for the reply, was married in your country, florida this year so wanted it put on dvd,
