    Jun 2004
    Lebanon
    Hello all,
    suppose i captured a tv show 1.5 hours as mpeg2 and now i only need to save on hdd for future view. Is there a way to cut commercials and add simple fade out/in and then saving the file excatly of same resolution without having to encode the whole file ?
    thank you
  2. I think people use womble for that. I don't edit mpeg-2 so I know knowing more....
  3. Member Moonstomp's Avatar
    Oct 2003
    Dublin, Ireland.
    Gondor,
    This software can remove unwanted segments (i.e. commercials) from mpeg2 files.
    https://www.videohelp.com/tools?tool=600#comments
    Moonstomp.
    Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials)
  4. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    VideoRedo is good for not requiring a reencode, and it's insanely fast.
