    Jun 2004
    Melbourne, Australia
    Hi,
    I am using DVD Decrypter to Demux and Tmpgenc'c Mpeg-Tools to re-attach Ac3 files to Video (Mux).
    What are you guys using and is there a better software than the ones i use?
    Thanks.
  2. I ran a quick search in the tools section to find all the relevant tools:
    https://www.videohelp.com/tools?toolsearch=mux&s=&orderby=Name&convert=&dvdauthorfeatures=
    See if you like those any better.
    Is there anything actually wrong with TMPGEnc tools that makes you want to change, or do you just fancy trying something new?
    Cobra
  3. I use bbmpeg to multiplex m2v amd ac3 when needed...
    Jun 2004
    No, Tmpg Enc's Mpeg Tools works fine but i was enquiring if there was another bit of software that you guys think is better.
    One thing i was wondering though, is it possible to make a short cut on the desk top for Mpeg tools rather than opening up Tmpg Enc Plus and then clicking on Mpeg Tools??
    Is this possible?
    Thanks.
  5. I don't think so since TMPGEnc MPEG Tools are part of a menu within the application itself. Maybe you could write a script like you can with AppleScript on a Mac? I've never done this though.
