Soon i can update my DVD-writer so it can burn "double layer". Now my question is: do all standalones play these DVD's or not, or will it depend on certain brands, series,......??
Results 1 to 11 of 11
All DVD Players will play Dual Layer discs , remember that most of the commercial DVDs we buy are Dual Layer.
I 'm not sure if anyone has successfully burned a D/L disc yet , even to play it on a PC , let alone play it on a standalone player. -
The was an article in PC Magazine about this last month. Johnny CNote posted a link to it a few days ago. Results weren't encouraging... yet
Hello,
Does anyone know if Pioneer will release firmares for the DVR-104 and the DVR-106 to make them dual layer compatible?
I know the DVR-104 is - writer but i've heard the -R/RW DL format specification is close to completion!
Also if anyone knows, if LG will release a firmware for GSA-4082B DVD Writer to make it dual layer compatible?
Thanks,
Adam (1 July)For Queen and Country!!! -
Adam , you should start a new topic for your question it won't get seen hidden in someone elses topic.
As for pioneer if they did do firmware it would likel;y be for the 107 but more likely not and the'll probably bring out a 108 for D/L.
But at £14.99 for 1 DVDDL+R , and the fact that the results so far have been far from encouraging ( ie they don't work).
I think it better to wait till they start working properly otherwise is a lot of money to throw away . There are no RW discs as yet for D/L so if you get it wrong its in the bin. -
Few players play customer written double layer disks.
These aren't nowhere near commercial authoring media double layer disks, which are $$$. -
Ta Andyp1,
I'm sure i saw an english website selling DL Disks for £8.99 when i searched using google!
I suppose your right, it'll most likely be for the DVR-108!
Might as well wait until the second generation DVD-RW DL writers are out and the initial problems have been solved with the first generation drivers.
Once again, thanks!
Regards,
AdamFor Queen and Country!!! -
Andyp1 you write:
"All DVD Players will play Dual Layer discs , remember that most of the commercial DVDs we buy are Dual Layer.
I 'm not sure if anyone has successfully burned a D/L disc yet , even to play it on a PC , let alone play it on a standalone player".
Can you be more specific Andyp1, how come homebrew double-layer-DVD 's won't do it, what is actually the difference with commercial, what do they have more then? -
authoring media only comes in two flavors: 3.95 gb and 4.7 gb which only record on the pioneer s-101 and s-201 authoring recorders, smaller laser wavelengthOriginally Posted by handyguy
not sure what youre talking about, "authoring media" double layer discs dont exist -
I take it was is ment is commercial disks that are pressed rather than burned. I've seen mixed results on double layer media which I can't even buy yet
let alone at a resonable price. If you change the bit settings to DVD-ROM I have heared that they do work in quite a few players. Until the disks are available to a few more people we won't know how good they are.
As above
Commercial discs are pressed together they are not made by burning them.
I have seen various threads on this site and it looks like the discs burned play upto the switch between layers and then have problems , I'm sure it won't be too long before they figure it out.
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
Are all DVD9 double layer?
By jyeh74 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jan 2010, 21:42 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 14:26 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 12:27 -
Double Layer DVD
By nagihcim1 in forum Newbie / General discussionsReplies: 1Last Post: 7th Sep 2007, 20:09
