Results 1 to 10 of 10
  1. Hi,
    i used dvd2avi to rip a DVD video out to my pc (folder VIDEO_TS). I played the vob files using videolan and it was fine. No pixels. After burning it, and playing it on a samsung DVD player, there were pixels. But, when it is played on the pc, there isn't any pixels.
    Could it be my burning problem? I burned at 2x
    thanks
  2. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    What kind of media are you using?
  3. imation DVD-R
    Mar 2004
    Israel
    depends on what kind of problem is it? pixels throughout the movie? just in the end? i've had similar problems due to software... but if you're using crappy media that could also be the reason...
    With all due respect... and there is respect...
  5. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    have you tried any other kinds of media?
    Mar 2004
    Israel
    hmm... try higher quality media... sounds like that's your prob after all... always keep around a few 1st class media (see media forum and www.nomorecoasters.com).
  7. Member GKar's Avatar
    Jul 2003
    In the corner, on a stool
    Originally Posted by ylkien
    imation DVD-R
    This doesn't tell us what media you are using, try dvdinfopro and then check it against the list at:
    http://www.digitalfaq.com/media/dvdmedia.htm
  8. Thanks for the info. This is what i got after running dvdinfo
     Media Information
    Region information                                    N/A not a DVD-VIDEO
    Media code/Manufacturer ID                                       CMC MAG.
    Format Capacity                                             Not Formatted
    Free Blocks                                                     412352512
    Free Capacity                                              4.38GB(4.71GB)
    Book Type                                                           DVD-R
    Media Type                                                          DVD-R
    Media Id Code Speed                                               Unknown
    Available Write Descriptor                           CLV  2.0x   2770KBps
    Write Strategy Speed                                        1.0x 1385KBps
    Data area starting sector                                          30000h
    Linear Density                                                0.267um/bit
    Track Density                                                0.74um/track
    Number of Layers                                                        1
  9. Member GKar's Avatar
    Jul 2003
     Media Information
    Book Type                                                           DVD-R
    Media Type                                                          DVD-R
    Number of Layers                                                        1
    I'm pretty sure that CMC -R's suck, I had some CMC +R's that burned ok, they had some weak spots towards the last 3/4 GB mark. Try burning only up to about the 3.75-4.0 GB mark and see if the pixelation goes away. It may seem like a waste of disk space but it may work. If you are using DVDShrink just use more compression to get your DVD's below that 4.0 GB mark. Don't label your dvd's either it will only exacerbate the problem.
  10. Video Restorer lordsmurf's Avatar
    The disc has a 1x write strategy. Should not be burned 2x.
    Disc may be okay if it plays in the PC, and just a bad DVD player.
