    Apr 2004
    Melbourne, Australia
    I have had trouble with disneys brother bear, if i make a movie only rip with mtr, it wont play opening the ts folder, it seems to have the menu vob in it with sound but no picture? so then i tried whole disc and then dvd2onex, drag it to toast and the file is 4.5 g? can anyone give me some ideas please.
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    how about trying the other set of rippers.........
    disney movies always seem to be a pain no matter what you do
  3. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    How about doing movie only in MTR, and then post-processing with DVD2OneX, even if it's already small enough? Sometimes, that fixes it. Otherwise, you can try running DVD2OneX on the 4.5 GB output another time, or just run it again on the source with a smaller user defined size set.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
    Apr 2004
    Thanks galactica you gave me a working download of osex, i will try to use it on my kevin & perry go large dvd, mtr wont read it, dvd back up cant read one of the vob files.
    Back to the brother bear dvd i tried WiseWeasels suggestion and ripped movie only then dvd2onex and it works!! how strange for it to work only after dvd2one. Thanks WiseWeasel
