I have been using DVD labs for a little while and am quite happy with it. I was wondering if anyone knows of any advanced effects guides. Cant seem to find any to give me some pointers.
One thing I want to do is change the color of the lens flare? (currently red)
VHS is a dying breed
Sad but true. -
I recall one guide (here) on text effects.
Lends flare color is fixed. You cannot change it.-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
aragorn234 wrote:
One thing that you can do, is export the menu (with the lens flare) as a psd. You can then edit it in Photoshop. All your layer will be carried over, so you should be able to change the color of the lens flare in Photoshop. Of course you can always make your own lens flare within Photoshop (that's what I do). When your done, just import the edited psd into DVD-Lab.[/code]One thing I want to do is change the color of the lens flare? (currently red)Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
More dvd lab questions
By sterankin in forum Authoring (DVD)Replies: 12Last Post: 16th Aug 2010, 17:13 -
DVD Lab Pro 2's Render Menu Motion - Intro and Loop Questions?
By xhonzi in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2009, 18:52 -
dvd lab pro 2
By m baqar in forum Authoring (DVD)Replies: 6Last Post: 7th May 2008, 02:39 -
DVD Lab Pro - Three elemenetary "hot to ....." questions
By perfection in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 07:45 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 08:52
