I don't have WS TV right now, but I'm sure I will somewhere down the road. Considering I didn't encode my VCDs with anamorphic, will the black bars still be on the screen or will the TV automatically adjust for it?
Most DVD Players have a zoom functon you could use to adjust.
This plan is so bad, it must be one of ours. -
Even the sides will have it? I would have thought only the top and bottom.Originally Posted by SoCalMK
The thing about zoom is that it will make the picture the even less clear than it already is.Originally Posted by Darth Paris -
The VCD format does not support 16:9 Enhancement, so on any display that automatically changes the shape of the picture, you will simply get black borders on four sides. If you manually adjust the picture shape, it will take advantage of the widescreen shape, but it will look like crap.
So the short answer is yes. Even if you did try to encode your VCD anamorphically, it won't look pretty on anything but a 66cm widescreen set, which is really a waste of money anyway. Even displays with the ability to auto-adjust will not do this because they have to see a flag in the video stream in order to do it."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
All you need to do is to zoom in on your widescreen TV display. Usually there are 4 modes (4:3, 16:9, zoom and auto-switching) just select the zoom mode and that will get rid of your black bars on the top and bottom of your picture. You will notice a deteriotion of picture quality as it is only a VCD image source, but it will work and will keep the correct aspect ratio.
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 12:59 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 21:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 23:15
