Hi guys,
Is it possible to have a DVD authored so that it switches in real time
between 16:9 letterbox and pan&scan?
I need to do this 'cause some of my captured dvb videos are native
16:9, but switch to "4:3 within 16:9" for some clips.
When this happens I want the video displayed in center-cut (pan&scan) mode.
I read in a different forum that DVDMaestro can do it . Here's how it was put "having the ability to have both 16:9 and PanScan (say for music videos) flipping happily throughout the entire length."
Thanks in advance,
Keith
if it were split into different titles it would be easy to do, not sure if it's all the same title.
also, this will make the video a bit funky when you're viewing on a wide display, it would switch between corret aspect ratio and a stretched ratio... -
Thanks for the reply. Splitting the video is too much work. Also, I wouldn't bother about wide displays as I don't have one.
only a matter of timeOriginally Posted by keithsebastian
Seriously, it's worth thinking about - i've gone through replacing a load of material i made before i had a wide TV, wish i'd done it for wide first time round!
HCenc and PanScan
By Comp360 in forum Video ConversionReplies: 2Last Post: 14th Mar 2011, 18:35 -
flip video to DVD
By Beefer in forum MacReplies: 6Last Post: 2nd Feb 2011, 13:35 -
Choppy Flip MinoHD playback when not using Flip software
By drsmartz in forum Software PlayingReplies: 5Last Post: 4th Jun 2009, 11:20
