I'm playing around with Audacity trying to get rid of hiss/noise from analog camcorder captures. What filters& settings have you used to remove hiss/noise & clean up VHS captures? Been gussing with noise reduction & low pass filters but don't really know what parameters to use.
	Look at this:
 http://www.digitalfaq.com/dvdguides/restoration/audio/soundforge/soundforge.htm
 I've never used Audacity, but maybe it will give you a clue for settings in that software. Hope it helps.Want my help? Ask here! (not via PM!)
	Thanks for that - I'm trying to see what on those menu's seem analagous to the stuff on Audacity.
 There's references to high & low shelf's which may to be like the high/low pass filters on Audacity. What units are the numbers in the examples for high/low shelf? Are they hz (that's the units on the Audacity menus)
 The 'noise/hiss' sound I have from my captures is more of a low sound.
 That's the main thing I'm trying to eliminate or reduce.
	If there is a section with just the noise, you can use noise reduction to isolate the sound and then remove it from the entire clip. I have found that the wav editor that comes with Nero does a better job of this.
	Tried the noise reduction. Didn't work too well for the audio file I was using. Low pass filter worked better, just trying to get a feel for the input to it - or other possible techniques. I have Nero 5.5.10.something , will look into that also.
  Audio Hiss Problem--I tried audacityBy bbbbbbb45 in forum AudioReplies: 16Last Post: 15th Apr 2012, 09:55
  Need advice; using Audition to remove hiss (and noise?)...By takearushfan in forum RestorationReplies: 22Last Post: 4th May 2010, 05:29
  hiss removal on a good quality VHS tape?By zee944 in forum AudioReplies: 78Last Post: 26th Mar 2009, 05:28
  'S' letter hiss (not general hiss on idle!) - help neededBy zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 05:54
  remove one of the channel with audacity..By sharmine in forum AudioReplies: 2Last Post: 16th Sep 2007, 20:52
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
