This is a real shot in the dark
Bought this DVD player a TBX DV-808 about a year back which has presumably now closed down as whenever i try to ring the number the line goes dead
The shop made it multiregion, but it's now reverted back to factory settings which is no use cos whatever that is is not region 2 (all our DVDs are regions 2, cos that's the region for where i live)
Basically, cant find anything about the player, no manufacturer's homepage, nothing. All i need is a code to make it multi region (even back to region 2 would be great), but there's no info in the manual (presumably cos the shop did it). There's nothing in the manual for contacting the manufacturer - which might as well not exist for all i know
If it helps, here's a link for one being sold online:
TBX DV-808 on inest.co.uk
Has anyone heard of the player? Any help much appreciated, otherwise am gonna have to chuck it cos it's of no use locked in a region which i have no dvds for. It was cheap, but a good player
Many Thanks
Sorry bud only just seen this post,
Well if you still have the machine the code is: -
Open Tray
Enter 9735 on Remote Control
Select Region 0
