Hi,
I have a DVD that was purchased in the US in NTFS and I want to convert it to PAL so I can play it in a UK DVD player. How can I do this keeping the menu /DVD format. Is there a simple DVD ripper and frame rate converter that will do this for me.
Thanks for your help
Joolz
Changing framerates is far from simple. I haven't done it as my dvd player can play both formats. There are guides here: https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=&howtoselect...or+List+Guides
Hopefully this will help you or at least get you started. -
you CAN'T convert to pal and keep the menu intact, unless you do that menu manually, with Adobe dvd encore or something similar
you have 3 options:
1. most european dvds play ntsc, and most tvs play ntsc, so no need for conversion.(THE BEST)
2. convert ONLY the main movie file, I use Canopus Procoder, is by far the best.
3.get a dvd player, that does the conversion on the fly, and can be unlocked.
have fun -
Depending on the size of the disc, either burn a new copy with Decrypter and set the region to all, or if it's too big for a straight rip use DVD Shrink.
As the resulting disc will be region free, it should play on your player/tv. Almost all European equipment can play NTSC - you'd be very unlucky if yours cannot. -
DVD2SVCD can do the job for you but you will have to forget the menus
If you backup the DVD with no region protection, you will most likely be able to watch it on any standalone player.
Just for the record, it's not NTFS. It's NTSC. NTFS is a file system used by some OSs, like WinXP and 2K, whilst NTFS is a TV system used in the USA and some other countries. -
Most UK dvd players will quite happly play American format disk, its the region code that causes the problem. You may be able to hack your player so its region free. Have a look in the sections on the left if not consider getting a cheap player as many of these are region free...Originally Posted by joolzhainesNot bothered by small problems...
Spend a night alone with a mosquito
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 14:36 -
DVD player w/USB NTFS format?
By usaRaydar in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Nov 2007, 14:12 -
convert PAL HDTV 1080i -> PAL DVD 576i
By halsboss in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 21:13
