  1. I have a muxed Mpeg1 NTSC file with the standard MP2 224kbit and 44000Hz audio that I want to convert the audio to the same MP2 224kbit but with a 48000hz frequency. I want to author a DVD with toast using these Mpeg1 files (not converting them to Mpeg2). If I set toast to do the task it converts the files (or at least alters the audio from 44KHz to 48KHz) but the sync is out.
    I have tried the passthrough video and set the audio frequency change to 48000hz in ffmpeg but I also get the same syncing problems with the resulting Mpeg1 muxed files?
  2. I'm not sure about which process exactly you're following. You can also consider the S/VCD>DVD tool if you use the registered version.
  3. This is the process I have selected below. I don't think the SVCD->DVD trick will work as the original file is not Mpeg2 (480x480) SVCD format it is standard VCD format. As you can see from the process that I am just passing through the video so it will be muxed at the end. It is only the frequency of the audio that I am changing.....
    Encoding started on Thu Jul 1 09:35:07 EST 2004
    Input #0, mpeg, from '/Users/mydirectorywiththefileinit/filename.mpg':
    Duration: 00:42:51.2, bitrate: 1393 kb/s
    Stream #0.0: Video: mpeg1video, 352x240, 29.97 fps
    Stream #0.1: Audio: mp2, 44100 Hz, stereo, 224 kb/s
    Output #0, avi, to '/Users/mydirectorywiththefileinit/filename.mpg':
    Stream #0.0: Video: mpeg1video, 352x240, 29.97 fps, q=2-31
    Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    Stream #0.1 -> #0.1
  4. Originally Posted by Falcon500
    The S/VCD>DVD tool will accept both SVCD and VCD as input. Otherwise try to convert audio only and remux video and audio.
  5. Sorry I miss understood how the SVCD ->DVD tool worked. I have tried just encoding the audio and then remuxing with the video but it is still out.
    How does the S/VCD->DVD tool work? Does it convert the Video to Mpeg2 ?
    I haven't got the full version of ffmpeg to try this feature.
  6. Originally Posted by Falcon500
    It automatizes the demuxing, audio resampling, remuxing, and reauthoring of any number of MPEG files, VCD or SVCD files located inside a folder. The video stream is not re-encoded.
