  1. I wanted to try RecordNow Max 4.5 because I understand it supports data verification when using multiple burners to burn a disc image file.
    However all the links lead you to RecordNow 7.2, so I downloaded 7.2 assuming it was a suite of tools including 4.5 and the features I was after. That isn't the case - I can't see any support for multiple burners etc.
    Maybe I'm just getting too old and stupid, but can someone point me in the right direction here.
    The stomp site has a link to a trial download of RecordNow Max 4.5, but in fact all the downloads listed are for other products. There's also a link to buy RecordNow Max 4.5, but that just takes you to RecordNow 7.2. I'm confused!!
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    it is owned by sonic now
    RecordNow 7.2 is a piece of crap and should be avoided ..
    4.5 is a good product
  3. You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  4. Banned
    May 2003
    Massachusetts
    PX Engine updates should/will continue to work on the 4.50 version. All new versions basically suck...
    Well, I think there was a 4.6 that wasn't too bad. But all the new SONIC versions suck. (6.x and 7.x)
    - Gurm
