  1. Hi
    I have a DivX AVI which I have downloaded and am trying to convert it to MPG 2 for DVD Authoring. It is 23.97 FPS with AC3 audio. I have extracted the audio using VirtualdubMod and then fixed it using BeSliced. I have converted the AVI to MPG2 (video only) using TMPGenc but when I create the DVD using TMPGenc DVD author (with the fixed AC3 audio as the soundtrack) the audio is up to 15 seconds ahead of the video!!!!! Not good!
    What am I doing wrong?
    Any Ideas??
  2. Is the video being converted to 29.97 FPS in TMPGENC? You might need to apply the 3:2 Pulldown option.
  3. Hi, Thanks for replying
    I have selected the 3:2 pulldown in TMPGenc.
    I have recently found out that during the BeSliced AC3 fix routine, 15.5 seconds have neen removed from the total length of the audio during the fixing process. Think I need to just add 15.5 seconds on silence to the beginning of the AC3 soundtrack and then put it through BeSliced....My then be the correct length.
