I don't suppose you could e-mail me a copy of QuickTime 4 I would REALLY appreciate it!
Cheers!
I hate to be a bother but would it be possible to also get a copy of the QT4.0? Emailed I did the same thing. Thanks Zap2 if I can get a copy or where I can get it.
Thanks John -
Is there some way to add quicktime 4 to the tools section because a lot of people (ok me too) have installed 5.0 and got screwed
hi guys,
after searching for quicktime 4 my girlfriend actually found it for me on apple's web-site!
be sure before you install it that you completely unistall quicktime 5. even though it tells you it's not recomended, you'll have to choose the 'remove all associations' option.
then install quicktime four, and enjoy!
http://www.apple.com/quicktime/download/support/
perhaps this link should be added somewhere in the conversion guides, as it is needed to make the qt_reader function properly
. cafe80s . -
Hi,
I can Convert .mov to Mpeg with the QTreader plugin for TMPGenc with QuickTime 5 installed.
Yes you are right that it doesn't work when it's not registered but once you register it then it seems to work for me.
How to play Quicktime with PNG codec on my videoplayer (not quicktime)
By Henkie in forum Software PlayingReplies: 0Last Post: 11th Nov 2011, 03:50 -
Quicktime Pro 7
By JBird in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 10:15 -
Quicktime
By skipowder1 in forum ffmpegX general discussionReplies: 1Last Post: 19th Jul 2009, 17:12 -
quicktime
By devdev in forum Video ConversionReplies: 2Last Post: 28th May 2009, 03:40 -
Quicktime 7.4
By matthewjohn23 in forum Video Streaming DownloadingReplies: 1Last Post: 4th Apr 2008, 15:42
