Hello all
I am extremely a newbso please forgive my ignorance.
I am trying to transfer dv from my Sony minidv but my avi always having problem. I first transferred with 720x480 and video jerks and sound cuts. I then tried 640x480 and the file was ok but on fast motion it blurs and I can see wavy horizontal lines. I am using easy Roxio DVD creator 6 .
I searched the forum and got much help and I think I need a good capture tool better than roxio. I have almost all software I need, but I am totally lost on how to set the capture settings. I would appreciate any ideas from where to start doing my capture.
horizontal lines is normal, it is called INTERLACED.
read
http://www.digitalfaq.com/capture/dv.htm
and
http://www.digitalfaq.com/capture/interlace.htm
then try anyway some other tools for best dvd quality,
copy the dv to your hd with windv or dvio or scenalyzerlive.
convert to dvd with a good mpeg encoder like mainconcept mpeg encoder or tmpgenc or cinemacraft encoder.
author with to dvd tmpgenc dvd author. -
I've copied and then authored a few dvd's off my sony, you get that on the pc, all that you described, but when you put it to dvd it works great...
I have used dvio, works great, very little lost frames, but I don't like having to convert and the avi file for almost 1 1/2 hours is about 20gig..
my last one I used Unlead dvd maker, it converts on the fly, but when I converted to dvd I lost all sound, so I took the file and tried tmpgenc dvd and it came out pretty good..
hope this helps.. -
I switched to pwerdirector3 it does a great job, transfer, edit and render to avi or mpeg1,2 . The only problem now is that I have small quality loss when transferring from minidv (interlaced), only on fast scenes motion and can't seem to avoid this.
I also tried transfer using scenalyzer and still have interlaced footage.
Any ideas?
Thank you -
DV camcorder footage is INTERLACED and should be left that way.
If the capture looks "worse" than playing back on a TV it is only because a computer monitor has a much higher resolution and shows compression problems easier than a TV.
bad quality of camstudio recorded avi video merged by avs video converter
By shimi in forum EditingReplies: 5Last Post: 25th Feb 2010, 15:33 -
Video Captured Low in Quality/Resolution
By kakashi123 in forum Capturing and VCRReplies: 4Last Post: 10th Jul 2009, 18:36 -
Captured HD Video - want to put on DVD in HD quality
By Coroner in forum Newbie / General discussionsReplies: 6Last Post: 7th Dec 2008, 15:32 -
Bad video quality
By windofice in forum Newbie / General discussionsReplies: 8Last Post: 16th Jan 2008, 21:20 -
captured video has bad color problems
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 04:24
