is there a significant difference between using normal vs high quality motion search precion in TMPGEnc Plus 2.5 when encoding...
i got 100+ mpeg,avi,wmv movies in my computer (all porn), and i need to convert them to vcd format so my friend will be able to view them all on his vcd player until his eyes turn red and pop out...
i got pentium IV 2gig pc and another 1.7 gig pc...im not planning to use any other filter like noise reduction since my sources are dvd like quality or though i need to use filters?
help me on this guys, i need to impress my friend on the quality of my output...![]()
I've used the normal, high and highest quality settings... I can't tell any difference between high and highest. I also set DC Component Precision to 10 bits. Filters can slow things way down...
you really didn't have to add thatOriginally Posted by d_unbeliever
I always just encode at the highest quality, because time isn't usually a facotr for me. If you really want to impress your friend(if thats actually who they are for) then you should encode at the high quality setting. -
Depends on what you're doing.
Read the TMPGENC CONVERSION guides at my site.Want my help? Ask here! (not via PM!)
Diamond Search for motion estimation
By bijo911 in forum ProgrammingReplies: 2Last Post: 10th May 2011, 19:26 -
best motion search option to increase encoding speed while keeping quality?
By visualhippocracy in forum Video ConversionReplies: 4Last Post: 13th Jan 2011, 11:40 -
Mpeg4 Settings for TMPGenc give poor quality for motion.. see pic's
By drewzor in forum Video ConversionReplies: 14Last Post: 13th May 2009, 09:37 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11 -
High definition video from camcorder onto normal DVD. Is it possible?
By VEINBERG in forum Newbie / General discussionsReplies: 7Last Post: 6th Mar 2008, 20:03
