This is so frustrating. I have tried 5 times to back up Along Came Polly. The first time I just used DVD Shrink to shrink and burn. Near the end of the movie, everything pixelates momentarily and then freezes completely. I checked the original disc for smudges or scratches. It is a flawless disc. It plays perfectly in my DVD player.
I tried ripping the DVD to my HD with Decryptor and then using Shrink to shrink and burn. Same results as before.
Finally, I thought there might be a problem with the burning feature in Shrink. So I used Nero 6 to burn the files that were output by Shrink. Same results again.
I tried burning at 2X rather than 4. No dice.
I turned data verification on in Nero. It tells me that anywhere from 1 to 3 files are inaccesible.
What does this mean, and how can I fix it?
Results 1 to 30 of 35
I'm sorry, but what is DMA? What does it do, and which prgram should I disable it in? Thanks
direct memory access=dma
It allows your burner to access ram directly.
Go to your start menu----->settings----->control panel------>system----->hardware tab----->device manager---->IDE ata /Atapi Controllers------>right click primary ide channel------>select properties tab------->advanced settings tab------>under transfer, it should say Dma. -
Hey rock. This is a quote from another post involving enabling DMA.
Originally Posted by fritzi93 -
*sigh*
What you have described - end of the disc crapping out - is the most prevalent symptom of BAD MEDIA.
Buy some better discs, dude.
- Gurm -
I agree with Gurm and Treebeard. Either get better media or if you need to use these "bad" discs up, set DVDShrink to transcode to a smaller MB size. I think the default size is 4464MB You might want to set it to 200 - 300 MB less. You can find this setting, I believe in preferences (not sure 'cause I'm not in front of my home computer.)
I agree, end of disc crapping out is a media issue.
I see this when I use a DVD-RW to test my burns. But when I copy to the DVD-+R, I don't see the issue(good media I guess).
Try what louv68 says and lower your target size. I think 200-300MB is overkill, but it will definatley let you know if thats the problem or not. -
Originally Posted by louv68
The very first media I used when I first got my burner were the no name, cheapest I could find and they all started messing up towards the end of the movie. Switched to Ritek brand and never had that problem again. -
Now, inevitably, someone will come in here and proclaim that Ritek sucks, and that PRINCO are the way to go. *sigh*
- Gurm -
Actually, I use PRINCO discs. Are these not good? I have burned over 200 DVD's with these discs and never once had a problem. Could there be any other causes for my problem?
I changed the DMA settings like the first person suggested, but that didn't help. -
I think it may be a media problem.
I use Matrix (Taiyo Yuden) and have backed up Along Came Polly hundreds of times. I sell them on the street for $5, with a money-back guarantee, and haven't had a return yet (I'm at the same spot every day).
Remember the old Latin proverb:
"Erut si evoba eht fo enon"
-Unknown -
Originally Posted by Supreme2k
Originally Posted by tekkieman
I don't ever understand these pathetic attempts to cajoul someone into reporting you for 'illegal' activity and then crowing how dumb they are for falling for it.
Not exactly in the spirt of the AUP, is it?
The trick of a prick, shouldn't be tolerated and only turns people away from this site when all they're trying to do is the right thing.
W.tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Originally Posted by Treebeard
Originally Posted by Will Hay
But, for humor, Baldrick has given us the Off Topic forum. However, it is hard to keep some humor out of the other topics, like when you had your **ahem** "keyboard problem"!
If people are around long enough, they will eventually learn who's comments to ignore. -
didn't he misspelled Eurt??? -
Originally Posted by presto
To my #1 stalker and the people with lacking senses of humor:
Took jbelder a mere two weeks to find my post -
its not the media, its not the
burner ACP was distributed, before they found
out there was a problem with the pressing....
if you rent another one, same results will
occur!!!! -
Originally Posted by musher70
- Gurm -
His response makes perfect sense to me. You're just being adversarial. You think thses "small businesses" actually have a budget for QA? Please!
Nothing can stop me now, 'cause I don't care anymore.
Arrgh.. "Easy Video Splitter" doesn't seem to work with Windows 7
By Wakewatcher in forum EditingReplies: 10Last Post: 14th Jan 2011, 22:19 -
Media player Classic won't let me "navigate" using mkv files
By FatalX in forum Software PlayingReplies: 0Last Post: 20th Jul 2010, 20:51 -
DVD player won't play entire "avi" file
By hifiguy in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2010, 01:05 -
How to add subtitles link to "update ifos" doesn't work
By sinuhemoises in forum Newbie / General discussionsReplies: 1Last Post: 3rd Apr 2010, 14:35 -
xvid-AVIs won't play until re-saved in "copy"-mode
By Information in forum Video ConversionReplies: 0Last Post: 5th Dec 2009, 09:03
