  1. i used cce to try and encode an avi file, but the end result mpeg is only like 3 mins long where as the avi is closer to 30mins. any ideas?
  2. Member SaSi's Avatar
    Jan 2003
    Hellas
    I think 3 minutes is the limit of the evaluation version of CCE. Are you using a full/registered version?
    The more I learn, the more I come to realize how little it is I know.
    Jun 2004
    Cyprus
    I think CCEs demo versions add a watermark on your video (at least versio 2.50 did). I don't know about newer versions, but what settings are you using anyway? Are you doing everything correctly?
  4. ill check to see if its a demo im pretty sure im doing everything right, ive just found tmpgenc to be way too long for my liking on my cpu. thanks for the replys
