    Jan 2003
    Nassau, Bahamas
    i need to block the port that kazaa donwloads stuff of so my sister in law can stopp putting huge viruses on the comp, and i also need to block port 445 and 454, can anyone help or recomend going somewhere
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
    Feb 2004
    DF/W, TX
    Without knowing what you are running it is a little difficult to help, but here goes. If you are running W2K or XP go to Control Panel / Network Connections. Open that up and right click on Local Area Connections (assuming you have DSL or cable). Select properties, on the general tab, highlight Internet Protocol, select properties. Then on the next general tab select Advanced at the bottom, select the Options tab, click on properties, this will allow you to configure your ports. Of course, if you have some sort of internet security software this is much easier to do. I have Pc-Cillin which I can easily set what ports I allow to have data coming in, out or both. Hope this helps.
    Jan 2003
    Nassau, Bahamas
    ok now this is my new question, what ports do i regularly use for my internet traffic, and what ports does kazaa use
  4. Regular? That all depends on the user....
    Do you just want HTML? port 80
    Do you want secure HTML? port 443
    I could go on and on....Why not install a firewall like zone alarm and set it to admins then stop all traffic you don't want?
    Originally Posted by jagabo
  5. Yes, I Know Roundabout's Avatar
    Jul 2003
    ...in and around the lake
    This may seem like a dumb question, but if your sister in law is getting viruses from KaZaA, why not just stop using it instead of trying to block the port it uses?
    Anyway, the default port for KaZaA is 1214, the port you use most is 80, for your web browsing (http).
    If you used eMule instead of KaZaA, you wouldn't have the problems that everyone has with KaZaA and you'd get better downloads.
    Ethernet (n): something used to catch the etherbunny
    Dec 2003
    Yes if you give more info this will help. Are you useing a router, some of them will let you block certian ports.
    If you can't figure it out on the computer, maybe getting a router will do it.
    Mike.
    Jan 2003
    Nassau, Bahamas
    i did everything you guys told me to do, i went into the network properties section, and made post 80 the only accessible and still, when i went to download kazaa, then installed it, then removed the option to make port 80 the other port available, if the default isn't open, i was still able to donwload from kazaa...what must i do now, i heard pc-cillin is good
