Results 1 to 24 of 24
  1. Using DVDShrink to decrypt and shrink OR using DVDdecrypter to decrypt then using DVDShrink to Shrink?
    Is there a difference in quality using one over the other? I know DVDdecrypter is faster I heard, but image-wise does it make a difference to use both vs just DVDShrink? I know Shrink has deep analysis or something.
  2. Decrypt with DVDdecrypter, shrink with DVD Shrink.
    No particular reason why. Did it that way the first time, stuck with it since then. A creature of habit.
  3. Member steveryan's Avatar
    Jan 2003
    Manchester
    DVD Decrypter to decrypt, DVD Shrink to shrink (ISO), DVD Decrypter to burn the ISO. Works on my players, good enough for me.
  4. Whats ISO? I think I use decrypter to burn it as file? Then I just shrink it (not sure how u change it to ISO in Shrink?)
  5. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    actually, if the disc is a double-layer, I use SmartRipper to rip, and then DVD Shrink. If it's single-layer, I use Decrypter.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  6. Member steveryan's Avatar
    Jan 2003
    Manchester
  7. steveryan, I always just select my D: (which is my dvd-r burner) What is the difference between what I choose vs choosing the ISO?
  8. I always use dvd decrypter. That way I can copy the copy with no problems. I keep copies for my portable DVD player, that way loss or damage no big deal.
    Fred
    Panasonic DVD Recorder E50. (Standalone).
    Dlink DSM320 Media Lounge.
    Mitsubishi 50" 4:3 TV.
    Home built AMD XP2000 system with LG DVD Burner (WIN98SE).
    eMachines T3882 with Liteon DVD burner (WINXP).
  9. Originally Posted by fredpb
    Even after I use dvddecrypter, I open up DVDShrink, its still 1) analyzes it 2) encodes it (takes very long time) 3) burns it (with Nero) What then is the point of using decrypter? It doesnt skip any of the 3 steps in Shrink whether or not I use dvddecrypter.
  10. I use DVDDecrypter then DVDShrink then Nero. Though sometimes I will burn directly from DVDShrink instead of using Nero.
  11. Member 888888's Avatar
    Jan 2004
    Turdistan
    I use DVDShrink, then Nero 6 to burn DVD-Video. I have never had problems with this procedure so I never had the need to change it. I did install DVD Decrypter, but again, I never needed it since DVDShrink does such a good job.
  12. Decrypter
    Shrink
    Nero
  13. Member b_n83's Avatar
    May 2004
    I use Decrypter to rip, and Shrink to transcode, then finally Nero to burn. No matter what program you use to rip the DVDs, there will be no difference in the quality, since it will simply copy the original files to your HD. However, one ripping program may be faster than others, and may be better at reading scratched disks. You cannot really compare the two programs, because though Shrink can do what Decrypter does, it isn't the other way around.
    My opinions may have changed, but not the fact that I am right.
  14. Originally Posted by b_n83
    But even when I use decrypter, then shrink, shrink goes thru the same 3 steps. So actually using decrpyter plus shrink is 4 steps. Longer than the original 3 if I just use shrink by itself.
  15. Video Restorer lordsmurf's Avatar
    Simpsons season 4 barfed all over CSS using DVD Shrink.
    Forget that.
    DECRYPTER FIRST !!!!
  16. Banned
    May 2003
    Massachusetts
    When I transcode, I use DVD Decrypter or AnyDVD, followed by Nero Recode.
    Why use freeware that's lagging several versions behind when you own a license to the commercial version?
    *chuckle*
    - Gurm
  17. Member Treebeard's Avatar
    Aug 2002
    Dvd decrypter to rip
    Clonedvd2 or DVDshrink to iso's
    Dvd decrypter to burn
  18. DVDDecrypter then DVDShrink.
    Shrink seems to run faster from the HD and less stress on my DVD reader. Shrink would have to read it at least 3 times(analyze, deep analysis, Transcode). Then from there I can choose which way to back it up and weather to keep menus or not. And can use IC7 if I feel it has to shrink too much.
  19. Just shrink. I've got a DVD-Rom and DVDRW, so I can just start it, leave, and in about 90 minutes it's done.
    I don't care about "drive wear" since it's a DVDRom drive, it reads discs, it's doing what it was meant to do. It doesn't get any use otherwise so I'm not crying about it.
    If for some reason DVDSHrink has an issue with the disc (happened maybe one time ever), I use dvddecrypter.
    That includes if I run a DVD through Shrink before running it through DVD-RB
  20. Seems on my computer, the latest version of DVDShrink rips just about as fast as DVDDecrypter. Of course, you'll come across the odd disc now and then that Shrink has problems with. Anymore I just rip, reauthor main movie, no compression, save it, and let DVDRebuilder work on it overnight.
    Pull! Bang! Darn!
    Jun 2004
    Canada
    DVDDecrypter to rip then DVDShrink to fit. Burning is done through DVDShrink. Same as many people - a creature of habit. Worked that way the first time and haven't changed since. Have yet to make a coaster.
  22. Member
    Jul 2001
    I might be in the wrong place since only decrypter and dvdshrink were specified, but since others mentioned other tools...
    DVD5:
    -Decryptor ISO read
    -Decryptor ISO write
    That was tough....
    DVD9(small movie):
    -Decryptor all file mode
    -InstantCopy 7 (well worth the piddly amount it costs)
    DVD9(large movie):
    -Decryptor movie files only.
    -DVD2AVI to create m2v and wav
    -TMPGenc to re-encode to mpeg2 (wizard helps with figuring out the bitrate)
    -MF2 to author and create ISO (no menus, movie only)
    (Notice I didn't say SHORT/LONG movie....I hate it when people say "It's a three hour movie" WGARA...in this hobby, size does matter )
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  23. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Smartripper/DVD Decrypter
    DVDShrink/DVD2One
    Nero/DVD Decrypter
    It all depends on how I'm feeling. I use a separate ripper because I have found that DVDShrink can be picky on what it accepts. Another reason is that DVDShrink interfaces with the DVD Drive for quite a lot longer than just ripping with other software first. DVDShrink then gets a transfer directly from hard drive to hard drive, and my DVD drive's life is prolonged
    If you're happy doing it the way you are currently doing it, and you're having success with playback then good for you - stick to your current method.
    If in doubt, Google it.
  24. I have clonedvd and dvd2one, but hardly use them because I think the free programs do a better job. Makes me wish I'd saved my money.
    DVD decrypter to rip DVDshrink to shrink in ISO mode and DVD Decrypter to burn in ISO mode. I used to use Nero, but have all but forgoten since I can burn ISO with DVDshrink and DVD decrypter.
    I've just started to use DVD Rebuilder with QuEnc but having small problem with playback on 4 standalone dvd players. I read on another forum that I should reduce the max bit rate from 9000 to 8000 in the ini file so will see if that helps.
    My burns play just fine on my pc and the quality looks to be fantastic but they stutter on my standalone players. Some people complain about the time it takes to use DVD Rebuilder, but I just set on one button method, go to bed and wake up to a fantastic looking encode.
