hopefully this is the right place to ask this. i'm using womble mpeg editor to edit and change vob into mpeg. is there a simple way to do a fade in and fade out at the beginning and end of an mpeg file? i just want the first and last couple seconds to fade. if it can't be done relatively easily then i won't bother with it, but if there's a simple way to do this it would be a good effect.
Is Womble mpeg editor the same as Womble mpeg-vcr? If so you can use Womble -
well damn. i haven't used it for anything except cutting out mpegs, so i didn't even know it could do that. thanks. guess i should have checked it before.
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 12:45 -
Fade in Fade Out CD Music Software
By mn072065 in forum ComputerReplies: 0Last Post: 6th May 2008, 08:23 -
Fade in Transition Fade out scenes
By ancient in forum Authoring (DVD)Replies: 4Last Post: 30th Nov 2007, 05:04 -
fade in/fade out with smart rendering
By bmf in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Jun 2007, 13:33 -
Fade-in\Fade-out filter, VirtualDub MOD
By GangstaRap in forum Video ConversionReplies: 3Last Post: 21st May 2007, 20:58
