  1. Hello everyone,
    I have been having a problem joining more than two AVI files together. I have tried using VirtualDub and NanDub and have had the same outcome.
    If I join two files together then no problems. But say if I join 6 files together then it seems to join them but also has repeated segments joined in the file. For instance lets say I have six seperate AVI files called 1,2,3,4,5, and 6. My joined AVI would look like this: 1,2,3,2,4,3,5,6 (Note the repeating segments, not saying they actually appear in that order though)
    What I have been doing is joining the first two segements (1 & 2) creating a joined AVI, and then joining segments (3 & 4) to the first joined AVI, and then joining (5 & 6) to that joined AVI. That seems to work fine for me but was wondering if there is a way to do it all in one shot.
    On a side note all the files have the same exact specs.
    Thanks,
    Apr 2002
    The State of Frustration
    Hello.
  3. Thanks Tommyknocker,
    I was just reading about that in some other posts but haven't tried it yet. I will check it out tonight when I get home.
