tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Whats the reason behind this sig then will.
There's a member amongst us who has this notion me and curryman are one and the same
I logged on last night and as soon as I saw the user list it reminded me of this chap and I thought I'd take the opportunity to dispell his 'fears'
All in good fun
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
That sig doesn't really prove you're not the same person. All you'd need to do is log in as Will Hay, open another copy of IE and log in as Curryman. Unless there's something to prevent two different logins from the same IPOriginally Posted by Will Hay
I thought it was suspicious that you two got along so well .....now we know
I was pretty sure that was the reason, just wanted to checkOriginally Posted by Will Hay
Oh, great.
I thought I'd found the fool-proof way to confince the conspiracy theorists.
Oh, well, no matter
Don't forget who you're dealing with here, it wasn't long ago my keyboard was out of action for a week, as I'd been trying to plug it in the mouse port
Oh yeah. There was a bit of rude speculation as to what exactly afflicted your keyboard. At one point you got it solved and called your keyboard a "bastard"
A true Will Hay post
Remember Will: Purple = keyboard, Green = mouse
I'll bet you never forget that color code
Originally Posted by Craig Tucker
It's not you, is it?
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 08:28 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 02:30 -
Need to make test tool to test Dolby
By djai in forum AudioReplies: 0Last Post: 9th Jun 2010, 06:01 -
Test,test amd propus 630
By budz in forum TestReplies: 20Last Post: 1st Jun 2010, 00:46 -
PSP Test Clip: Need someone with a PSP to test for me!
By FulciLives in forum Portable VideoReplies: 5Last Post: 17th Feb 2009, 20:42
