I've been using DVD Decryptor and I'm trying to copy Bad Santa to my Hd But at 7% I get an error asking me to retry and when i choose retry. It's like the dvd can't be read anymore. I just finished watching the movie. Are there more higher quality programs that perform at a low level such as Dvd Decryptor? I only know of this program help me out Thanx
Try DVDShrink. Get the latest version
If you haven't already, try cleaning the disk. Even if it looks clean and flawless, a dirty or smudged disk is still the number one cause of ripping errors.
If you click on the tools link to your left and then click DVD Rip Tools you will find about 20 different DVD rippers. Hopefully one of them will be able to do the job.
Vstrip is probably the most difficult to use but provides the best results for hard to rip disks. -
If you notice any scratches or defects on the DVD surface, clean the DVD surface with some Brasso or toothpaste (dont remove all the toothpaste when rinsing). Works most of the time with problem DVDs.
My opinions may have changed, but not the fact that I am right.
Check DVD for errors
By Happichap in forum TestReplies: 1Last Post: 10th Mar 2011, 06:53 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Errors decrypting dvd
By Beaker14 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 10:59 -
VHS to DVD Errors
By bondc in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Jul 2007, 16:35 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
