I am having some VHS which I would like to convert to digital (avi, mpeg, etc.). Currently, I am thinking of buying a DVD recorder to do the job. Is it a good way of converting, or should I buy capture card instead? What are pros and cons of the two methods?
Thanks.
Results 1 to 9 of 9
DVD recorder: Quick, simple, restricted.
Capture Card + DVD burner + software: Slower, more complex, much more flexible. -
Also, using a VCR right into a DVD Recorder means you won't be able to capture macrovision-protected commercial VHS tapes. But that's also true of the PC capture setup unless you have a TBC or a capture card that bypasses macrovision.
You can also buy a DVD recorder, such as the Liteon 5001 or 5005 which can ignore the macrovision signal entirely.Originally Posted by Capmaster
Tom -
If you need or already have a DV camcorder, you can use it to capture VHS. You may still run into the Macrovision problem as bugster noted. You'll still need the dvd burner.
Oh yeah, I would think that the DVD Recorder would be higher quality (from what I've seen, some capture cards are just crap and you need a powerful computer not to constantly drop frames). -
Actually it was Capmaster who mentioned Macrovision.Originally Posted by evilwarmaster
Also, with a decent capture card, you have many more options such as post capture filtering and processing, never mind editing, than you would have with a standalone DVD recorder. So it is possible to get better results going down the capture card route than with a standalone. This is especially true if you have poor source material such as old worn VHS tapes. It does require a lot more learning/time/work than a standalone though, it all depends what you want. -
... hacked or old firmwares required ...Originally Posted by Thomas DavieWant my help? Ask here! (not via PM!)
If you already own a DVD writer then I would say buy a capturecard.AverMedia cards start off at $50USD and can capture 720x480 but the best results come from a DV camcorder or analog to digital converter via firewire.One benefit to using a capturecard is you can make menus or chapters with the right software.
SVCD2DVD Titleset Button Name Changes (when it shouldn't)
By DannoDanno in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 8th Sep 2010, 13:21 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
Shouldn't Sony Vegas Pro 8 capture DV avi via firewire?
By brassplyer in forum Capturing and VCRReplies: 6Last Post: 11th Jan 2010, 10:31 -
Vegas is rendering frames it shouldn't
By tripecac in forum EditingReplies: 9Last Post: 16th Jul 2008, 13:26
