From what I've learned, Premiere Pro 1.5 has the same MainConcept encoder as 1.0, right? However if you BUY the MainConcept HD Mpeg Pro plugin for like $200-300 then you can edit in Mpeg-mode without having to convert to another format?
My question is this... the MainConcept HD Mpeg Pro plugin has a feature for HD and regular DVD, is the regular DVD Mpeg-2 it encodes any better than the basic version of MainConcept that comes with Premiere Pro? Or is it the same thing? Cause editing in Mpeg-2 mode doesn't REALLY interest me. Although I guess it'd be nice to have if ever I needed it, but I do want something that is better than the MainConcept encoder built into Premiere Pro 1.5. I just don't find it's that good, I prefer Canopus ProCoder but 1.5 doesn't plugin to Adobe Premiere Pro well. I may just bite the bullet and buy Canopus 2.0 though. Cause apparantly ProCoder Express 1.0 is the only thing that works well with Premiere Pro. I think I read that somewhere, anyone know if it's true?
That brings me to another question actually do ProCoder 1.5 and ProCoder 1.0 Express use the same engine and yield IDENTICAL results? What's the difference. Based on version number alone, I would think 1.5 is an improved version of the engine and would perform a better encode.
Any one know?
Main Concept HD Mpeg Encoder uses the same engine as Standalone v1.42 encoder. I'm still using Premiere Pro v1.0, so I don't know what v1.2 uses. The version that comes with Premiere Pro is diferent than the standalone. It's a great encoder, I don't know why you don't like it. I think it's better than CCE and Tempenc, though I never tried Procoder.
Main Concept HD Mpeg Encoder will let you edit Mpegs. It worked great during my tests. I don't like the way it does still images and tittles though.
If you want to use Procoder, then simply use a FrameServer like Debugmode PluginPac FrameServer. You can then use any encoder you want.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Thanks. I have a question about Frameserving too actually.
Can you carry over chapters? That's one thing that at the moment the MainConcept Mpeg Pro HD encoder can't do (as of 1.04 but will be fixed in 1.05)
Will frameserving to Adobe Canopus allow me to cut chapter points in Premiere encode to Mpeg-2 and then throw into EncoreDVD / DVD-Lab?
Or will I have to recut chapters after Mpeg-2 encoding is done? -
As far as I know, you'll have to set your chapter pionts in your Authoring App. I could be wrong though.
Adobe Premiere - MainConcept's H.264 vs x264 open source encoder
By rallymax in forum EditingReplies: 159Last Post: 19th Jun 2012, 19:51 -
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Exporting Premiere Pro CS4 Project - Adobe Media Encoder question
By schmickers in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Jan 2012, 18:51 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17
