Okay, this damn movie is driving me insane!!!! It plays perfectly fine in VLC, but not Quicktime, I finally got it to encode using the regular DVD settings, slower, but at least it worked, after a looooong encode, the video is gorgeous, very nice, and my audio is......electronic screeches and nothing more, it encoded as mpa, and I tried to change to mp2, but still garbage, how can I get the audio out of this??? I've tried every audio preset, and they all encode in less than a second with nothing to show, and every single process output is the same "unknown format", yet VLC tells me it's "vorb" and I've done good encodes from the same formats before!!!! HEEEELLLPPP!!!!!!!
I'm sure you're aware that vorb is ogg audio. You can convert this to mp3 with iTunes if you have the QT ogg codec installed.
Oh, it's an avi? You might be SOL
DivX Tool is worth a try, I'm not sure if it can do ogg though. Last resort might be something like AudioHijack or WireTap - play it with VLC and record the audio.
Almost forgot, you could also try VLC's transcode feature. Choose 'Open File' (do not drop onto the VLC icon), advanced output, settings, output to file, select audio, mp3, bitrate etc, and see what happens. This didn't work very well in the last version of VLC so YMMV
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
