    Dec 2001
    Dallas Tx
    I was using the method of cloning a dvd movie using AnyDVD and CloneDVD. I got to the last step in the CloneDVD section where I can begin creating my dvd file and burn it directly to a DVDR. Anyways, i accidently cancelled it when it was like 60%, I later look at my C:\ and realized that 3gb was gone! I went to the C:\CloneDVDTemp folder but i could'nt find the 3gb there, I've also serach my whole computer for the ifo files but I can't find anything that would add up to the 3gb that clondvd had created. If anyone know how to find the file(s) that clonedvd created before i cancelled, please reply ASAP! thanks.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Search your HD for VOB files.
    If in doubt, Google it.
  3. I'm a Super Moderator johns0's Avatar
    canada
    If you cant find the temp files(vobs) then most likely clonedvd deleted them,gotta start from scratch.
    Feb 2004
    WI.
    Do you have norton Antivirus installed? If so they could be in nortons protected recycling bin. Almost everytime I delete a movie from my drive it will end up in there. Then I have to go in and manualy delete it from there.
    I actually have it disabled now. Just because it was such a hassle.
  5. Banned
    Dec 2002
    just as a side note...that's Norton Systemworks you are talking about...not an issue with the Antivirus.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Nortons Protected Recycle Bin ships with Nortons Internet Security 2004, and I believe AV2004 as a bonus feature. It is actually quite handy because it also captures versions if you save a file while working on it. It has saved my arse a couple of times as I have been able to use it roll back word and other files.
    Feb 2004
    WI.
    I only have norton AV installed and I have it. I do not have Norton system work installed. I don't even own it. So it is in the AV.
