Results 1 to 17 of 17
  1. I brougth a music cd that is copy protected and dosent play on my PC (tracks are just 44k) can i make a backup of this cd or is it imposible. I tried CLONECD but the cd that was burn does not have any sound in it.
  2. Return it to the store you bought it from & demand your money back!
  3. THere is nothing out there to bypass the copyrigth anydvd something?
  4. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    You might want to try Easy CD-DA extractor. It works on everything I've ever tried it on. I'm using v7.0.
  5. Member Gillies's Avatar
    Feb 2002
    Sydney
    bloddy copy protected cds... i have one and it doesnt work on my standalone player.. keeps skipping... piece of shite... some cds take advantage of autorun and install copy protection software... it's basically spyware.. u can get around some by holding shift as the cd loads... oh and turn of autorun
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Return it to the store and tell them that the only cd player you have is the CD-RW in your PC
    Seriously though, have you tried any programs that can extract to WAV or MP3 ?
    Easy CD-DA extractor, CDEX, etc etc ?
    I have seen CDs autorun with the Interactual player embedded. Once you say yes to install, you will not be able to copy the CD. You need to cancel anything that its says you need to isntall when you put it in your CD drive.
    If in doubt, Google it.
  7. Try Anydvd it might help.
  8. If it has the autorun protection program and it already installed on your computer, goolge for a way it uninstall it (try "autorun copy protection" or "Bestie Boys copy protection") Otherwise try CDex, if that doesn't do it go for Isobuster. That has always gotten the data for me.
    -Suntan
  9. Member Treebeard's Avatar
    Aug 2002
    Audiograbber, rip that baby!!!!!!
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    That goes close to the worst call ever.
  11. Member steveryan's Avatar
    Jan 2003
    Manchester
    How could Anydvd copy a CD? Btw, this is in the wrong forum
  12. Is this that 'revolutionary' SunnComm copy protection that you can bypass by holding down the 'Shift' key when the disc loads?
  13. Member 888888's Avatar
    Jan 2004
    Turdistan
    AMEN!!! Anything else would cost you your dignity as a consumer. I am sorry but If you don't return it, you are a weenie who is letting the bad guys win.
    I personally refuse to buy any CD with this kind of BS, even if it does play.
    P.S.
    And if it is your friend's CD, demand HE get a refund.
  14. Member jbelder's Avatar
    Jun 2004
    Denver,Co
    Well If you ever used Any Dvd it has in its program to remove cd copy protection as well as dvd protection.
    James B Elder
  15. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    It does appear that AnyDVD can overcome CD copy protection.
  16. Member jbelder's Avatar
    Jun 2004
    Denver,Co
    Clone Cd also will work, I have not found any cd yet it would not copy.
    James B Elder
  17. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I have Roxio 5.3.4.21 - it has no problems with Copy Controlled CD's. That and CloneCD of course.
