Im trying to convert this avi file into a dvd compliant mpeg-2. The avi I believe is encoded with xvid. So I load it into tmpegenc wizard w/o a problem and hit next a few times. The video is 46min but it comes out to be 1 hour and 36 minutes! I'm not sure why either. I play it on windows media player and its fine, 46 minutes. Any way to fix this because it doesnt encode properl;y
MP3 audio and TMPGEnc don't get along. Take a look at this thread:https://www.videohelp.com/forum/viewtopic.php?p=941122&highlight=tmpgenc+mp3#941122
If in doubt, Google it.
Ok I made the audio into a pcm unsigned 16 bit stereo wav. I loaded it in and the length of the movie surely is 46 minutes which is expected. However when I do the actual encode I see the movie in the preview screen normall and then it becomes all black. The movie is still being encoded since I see the frame number moving but then after another 10 seconds or so it stops and I get an error saying "Cannot Read Video". Any ideas?
You must have the 'Direct Show Multimedia Filter ' set to the highest priority .
Also did you check your file for Bad Frames ? -
Just changed the direct show filter and it seems to be working!Originally Posted by andyp1
I had it on 2 which was tied with my dvd2avi plugin so I made the directshow set to 3 and so far so good. I better not speak too soon though as the encode isnt finished yet ^^*
vob file has wrong length?
By Brainbanana in forum Video ConversionReplies: 16Last Post: 1st Mar 2012, 15:52 -
Avi showing wrong length. Encoded with virtualdub
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 3rd Nov 2011, 13:06 -
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 09:08 -
Vob File Length seems all wrong
By AlexHaden in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2008, 20:34 -
CCE SP avi video wrong length
By skipadipadoo in forum Video ConversionReplies: 4Last Post: 7th Nov 2007, 12:14
