Hi
I convert my avi to svcd using TMPGEnc 2.5. I follow the guide on this website avi to svcd. I rip the audio using virtual dub. I load the movie and the wav file. After the encoding is finish. I burn to svcd using nero. When I play the svcd on my dvd player. I noticed the person lip is moving and then I hear the person talk 1 or 2 second later. Can anybody help me.
Results 1 to 9 of 9
Did you check for bad frames? Link below.
Is it out by the same amount all the way through, does it get progressively worse or does it go out all of a sudden?
Did you match the input and output frame rates?"Art is making something out of nothing and selling it." - Frank Zappa -
The video isn't out of sync on my computer. I think it only happen when I burn too nero. Is there away around this
Have you tried the DVD in another DVD player or on your PC?
Is your DVD player the Toshiba SD220E by any chance?
This is a known issue with SVCDs.
To solve this problem, press the 'Angle' button twice on the remote control when playing a SVCD.
Hope that this is helpful.Cole -
https://www.videohelp.com/dvdplayers.php?DVDnameid=2281&Search=Search&#comments
Have a look at the comments here.
It seems you are not alone in having the lip sync problems with the Daewoo.Cole
avi audio sync problem.
By Corpsecreate in forum Newbie / General discussionsReplies: 6Last Post: 14th Jun 2011, 13:06 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 11:31 -
Sync problem in AVI
By GordRocks in forum Video ConversionReplies: 3Last Post: 14th Nov 2007, 13:02 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22 -
riverpast rm to avi conversion sound out of sync
By princevegetam in forum Video ConversionReplies: 9Last Post: 2nd Jul 2007, 03:45
