I've used rebuilder with CCE with a lot of good results but had a problem with one disc - one of the discs of the Nip/Tuck series seemed to give me a lot of blocky noise on some of the backgrounds - is there a CCE setting that I can adjust that may fix some of this??? Right now I'm set at VBR Bias=10, Quality Prec=24, VBR Passes=4, and using CCE 2.67.00.23 with ECLCCE
-Trancer![]()
Try VBR- 2pass only. Lordsmurf said the same thing about noise from CCE using DVD RB. I use only VBR at 2PASS. I haven't experienced any background noise with using DVD RB & CCE.
__________________________________________________ ___________
on the slow PENT 933 pc again
Should audio track be smaller after DVD Rebuilder/CCE?
By hiimbored in forum DVD RippingReplies: 3Last Post: 22nd Jan 2009, 09:10 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
question about CCE Customized Settings in DVD Rebuilder
By jimdagys in forum DVD RippingReplies: 1Last Post: 30th Oct 2007, 04:20 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 09:04 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 11:56
