12 bit or 16 bit sound? Camcorder gives these two options. Which is better and why do they have two? Thanks
Results 1 to 10 of 10
12 bit is used for 4 track .. 16bit for two track ..
most people use 2 track"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks, I'll use the 16 bit then. Curious, the higher the bit- the better the sound too ?
yes
for example - dts audio cd's are 20bit"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Sorry to resurect this. I'm curious why the default is 12 bit. Every time I record on my camcorder, it has "16bit" displayed. Just wanted to make sure this was the better of the choices and why not set as a default? (does it take more tape or something) thanks.
Nope, no more no less tape. I myself have wondered why the default is 12-bit.
Always use 16 bit sound recording. Some NLS have problem working with 12 bit recorded sound.
The 12 bit is at 32K sample rate, it's used for 4 channel recording. My Sony lets me use CH 1 and 2 for audio while recording the video and 3 and 4 for a 'Voice Over' track. The 16 bit is at 48K sample rate on Ch 1 and 2. This is the default audio sample rate for DVD. So any recording using the 12 bit audio would need converted to 48K for use in a DVD project. I don't know why they all seem to come set to 12Bit 32K audio, if I'm doing a voice-over I'll do it in post.
I've been told that Japanese commonly use 12-bit 4 track for overdubbing in-camera, so the manufacturers set that to the default. Not a good idea, but ...Originally Posted by JimJohnD
One thing to note is that Premiere (and possibly other NLEs) doesn't like combining 12 bit and 16bit audio in the same project. So don't switch the setting while shooting video you may want to edit togethet later on.
Unless you're using multiple mics while taping you want 16bit.
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 02:17 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40 -
Vista Home Premium x64 (64-Bit) vs x86 (32-Bit)
By Shibblet in forum Media Center PC / MediaCentersReplies: 8Last Post: 30th Sep 2008, 18:42 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 12:12
