I'm trying to get rid of 2.5 - got 3 - but something must have been corrupted.
Anyway, I'd like to re-install (that should put back the uninstall file) but the http://www.pegasys-inc.com/ doesn't work. Anywhere else I can get the registered version?
Not sure exactly what you mean by "pegasys-inc doesn't work," but have you tried downloading 2.5 and re-installing that version?
http://www.pegasys-inc.com/en/download/tp.html
As a general computer tip, I've always felt safer uninstalling rather than upgrading on top of the existing version. It's the same principle that suggests a fresh install of Windows is better than an upgrade.[i.am.quiller]
simplicity rules -
Thanks. Yes, that's what I was trying to do - but the site was down for hours - now it's back.Originally Posted by quiller
Actually, you can't install 3 over 2.5 - you just end up with both. -
Another good reason not to try. The underlying moral lesson: Don't run with scissors and/or while upgrading over an existing installation.Originally Posted by loopyloops[i.am.quiller]
simplicity rules
Cannot uninstall Nero 9
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2009, 08:31 -
unable to uninstall ffdshow
By WinSpecToR in forum ComputerReplies: 1Last Post: 2nd May 2008, 02:25 -
Can't uninstall codecs
By boonebaker in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2008, 16:09 -
How do you uninstall WMP 10?
By rayden54 in forum Software PlayingReplies: 5Last Post: 8th Jan 2008, 15:59 -
How can I uninstall Huffyuv?
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Jun 2007, 10:55
